cbsnyder87
- Helendale, CA
Hello all,
OK, so I'll make this synopsis as short as possible.
-Went to client's home for data transfer from old dinosaur Win 98 desktop to new laptop. Client is elderly, has sentimental files on the old PC (husband and brother's funeral eulogy's, among other things), really needs the data transferred to new PC.
- Booted up dinosaur, started right up and ran great.
- Connect thumb-drive, not recognized (no surprise).
- Attempted to find driver but Win 98 requested install disc to search for drivers. Client doesn't have install disc (no surprise again).
- Removed HDD from dinosaur, connected it to a SATA/IDE USB interface and connected the Molex power cord. Turned on power switch. POOF...motor drive controller went up in smoke.
MOTHA-F*#*#$&*((*&(&*#)@*!!!!!!!!!!!
- Had internal argument with myself to lie to the little old lady, tell her the data is untransferable, put everything back together, and when she started it up next time (probably 2 years from now) she would think it's just dead.
- Decided I won't run business that way and told her what happened. Offered to order a new ICB and replace it for free. Offer accepted.
- HDD is a Maxtor and Maxtor ICB's do not require the BIOS chip to be transferred over, so ordered new ICB from DonorDrivesLLC and installed it today.
Here's the real problem:
The HDD now spins up, you can hear the heads moving, but the PC refuses to boot. Gives "Master Hard Drive Failure" error. Double-checked connections - GOOD. Double-checked master/slave jumpers - GOOD. Double-checked BIOS is set up to boot to HDD - GOOD.
I am terrified of using the Molex power cable of my USB interface, so I left the Molex of the PC's power supply connected and connected just the data connection of my USB interface to 3 different laptops (1 Vista, and 2 Win 8).
All 3 state the drive is unreadable and needs to be reformatted.
MOTHA-F*(#&(@&(*#&%#$)%(!!!!!!!!
CMD>MSCONFIG>Computer Management>Storage Devices... HEY! The drive is mounted and healthy. Oh wait... File System = RAW.
.............MOTHA-F(*$#&(@&(*#$%&)(&!!!!!!!!
Busted out Macrium Reflect to make a clone, reformat the HDD, and transfer the clone back to it. Macirum can't read the file system....
Busted out Recuva Pro to recover data and at least get her the files...screw the old computer. Recuva can't read the file system...
QUESTION 1:
Does anyone out there know if the file system data is stored on the ICB or is part of how the data itself is stored on the HDD?
I am 99.99999% certain it's the new ICB that is not formatted correctly. Why? Because the data on the drive was perfectly readable and working prior to the motor controller burning up on the last ICB.
If so, can I format JUST the ICB. In other words, remove it from the HDD, connect it to power and data, format it to NTFS, and the reinstal it?
QUESTION 2:
Recuva has a "recover from formatted drives" option. Should I go ahead with the reformat and then do a Deep Scan with recuva?
Since no data is being written or has been written to the disk since the ICB failure, would I have a high chance of recovery?
Thanks to anyone who answers!!
QUESTION 1:
QUESTION 2:
