HCHTech
- Pittsburgh, PA - USA
Had a frustrating workstation build today. Had the above with 16 gigs of RAM, a Samsung 970 NVMe drive and an Antec Gold 650 power supply. Got everything put together, double-checked everything and fired it up to start the hardware testing. Got lights and fans, but no post beep and no video. I know Ryzens sometimes take a while to come up the first time, so I let it sit there, but 2 minutes later, it still hasn't posted.
Nothing looked wrong, of course, so I started by pulling both sticks of RAM and I got no complaint beeps. Tried a known good power supply, same answer. Tried adding a discrete graphics card, no change.
Tried resetting the bios by pulling the battery for a while, no change.
Tried disassembling everything and booting a stripped down assemblage outside the case, no change.
I pulled the processor, nothing was wrong there, no bent pins, all good. Remounted it again but no change.
Well - either it's a bad motherboard or bad processor - wonderful. Luckily, I had a Ryzen 1800X in inventory, so I installed that and it booted to the bios normally. Before I call it, I decide to update the bios to the latest version. The board had 4.03 on it and the latest offered by the in-BIOS updater was 6.04. I did the update and it booted again, so I reinstalled the original Ryzen 5 2400G and this time it boots up. I remove the discrete graphics card I had installed to run with the 1800X and it still boots fine using the integrated video.
So, this seems a bit unusual for a board to require a bios update before a supposedly-supported processor will be recognized, and more unusual for the symptom of this required update to be a complete non-boot!
Just to close the loop, I checked on their website, and the 2400G is supposed to have been supported since BIOS version 318. Apparently not so much. I think I'll set that 1800X aside so it doesn't accidentally get sold. Thanks for the unplanned fishing expedition, Asus!
