Lersar
- Northwest Ohio
I'm looking for some reassurance on this. I have a customer's laptop, it's fairly new but it was one of those purchased online discounted with no warranty deals. The model is an HP G61-632NR, I had done some work on it when he first purchased it, it came in with a faulty CPU fan, replaced it without any problems. It's been several months, probably nearing a year.
Anyway, the laptop is stuck in a boot loop. You can catch a glimpse of a blue screen when it tries to load Windows normally. Safe mode through any manner just cycles back as well. Dealt with plenty of these before, take it back to the office and the first thing I try is accessing the recovery partition to do a system restore. Restore point is found, start it, great. After around ten to twelve minutes, the screen goes black. The LED indicators under the power button and wireless toggle are still on, and fans are still running. Naturally, I fear I just uncovered a back light problem as well. So I hook up an external monitor; no display.
Cross my fingers that it's a fluke, and try it again. Same results. Trying to run any start up repair, it does the same thing. So I test the RAM, and take the hard drive to test it, it comes back fine, no bad sectors or anything (probably nothing to do with the screen but I wanted to cover that base due to the boot loops). Just for the sake of trying, I grab a fresh hard drive an attempt to install Windows on it from the laptop, which leads to the same black screen.
I found a few articles indicating the model is known for faulty batteries, I've tried any combination of adapter only, battery only, adapter + battery, all sharing the same symptom.
There is no pattern or blink codes, either.
So at this point, my thought is that something on the board, probably something in the graphics, is what is causing a blue screen and the reported boot loop as diagnosed by the customer. If it is left to run in a manner without restarting (recovery, etc), the video fails. I even tried to let it sit on the BIOS menu, and sure enough, video dies out.
Any thoughts?
Any thoughts?
