bagellad
- Kingston, Ontario
Does anyone know anything they can do with these, except sending them to a professional?
If the data isn't worth anything then knock yourself out but if it's of value then send it to a professional with some kind of background in data recovery or learn how to do it yourself the proper way.
This is totally last ditch, but I know a guy that if all else fails he takes the drive and slams it down on the bench. Not the PCB side but the top side and square kind of like a belly flop.
I told him he was a nut but I have seen him do it a few times and recover a drive after words. These drives would not recover without it.
I personally would probably not try it unless the data wasn't important but this guy swears by it and from what I have seen it works.
Eeek....i'm surprised he didn't completely ruin the head on the drive or scratch up the platters to make data recovery more difficult. Sounds like a questionable method![]()
If you take your failed hard drive to a data recovery or computer repair shop and they say that they are going to freeze it or slam it into the ground, take your hard drive back and RUN!
Either of these methods tell me the following:
They don't know data recovery.
They don't know how to diagnose hard drive problems.
They don't have the proper tools to perform the recovery.
Ask anyone who puts drives in a freezer what they did to diagnose the drive and I'm sure they'll just tell you they just plugged it in and listened. They didn't check the SA, they didn't map the heads, they didn't check for weak heads.
A bad PCB could also cause the click of death...did they check it?
Places that do these kind of things usually cause more damage to the drive and sometimes you only get one chance to get the data off and they often ruin that once chance.
