AdvancedTech
- Upstate New York
Hello all...This is something I have never seen...maybe someone can shed some light on it.
A customer brings me a Toshiba Satellite P870 laptop that will not boot. The customer tells me that the system will eventually start if he leaves it for 4 or more hours.
I start it up and it boots ok. I check for viruses using Avast which I installed at the last service no detections. I run Malwarebytes it finds 3 instances of malware and I quarantined these.
I shutdown and re boot...no problems. I noticed there was a problem with the wireless driver. I resolved this rebooted and all was well.
After a few reboots...the system just stalls on reboot at a black screen. It doesn't appear that there is any sign of life at all (screen does not light up at all). I could not get it to boot to safe mode either.
I ran some diagnostics on the hard drive ( Gsmart...Western Digital Diagnostics..Crystal Disk Info....etc...and it passes all tests. I know that this is not the end all for hard drives but I felt that it gave me at least a baseline.
I tried booting to a Linux Live CD....no joy with this either.
I then decided to try to remove..clean and reseat the memory to see if that would help. Imagine my surprise when I discovered that there were no modules in the system!!
My question is how did the machine boot at all without memory? I actually got it to boot about 7 times before I encountered the same issue as the customer.
Has anybody seen this before?
Many thanks for your help!!
