brock029
- San Antonio, Texas
I have read through the forums and have not come up with a definite answer so I figure I'll ask. I haven't got too many laptops that have had things spilled on them, the ones I have had all just needed a keyboard replacement. Today a friend of mine brings me her Acer Aspire 7741z that her son spilled tea on last night (I am assuming sweet tea.) The computer will not boot and will not even post. There are no beep codes, no fans spin, nothing. Just the power light comes on and if you have the cable plugged in the charging light also comes on. She said "it made a beep sound and it was full of writing not sure what". Then she unplugged the power cable and it shut off instantly. The drive seems to be fine so getting data off should be no problem.
After reading through the forum it seems to be either A.) You clean the board and hope it works or B.) You offer to recover the data from it, and call it good. My question is what steps do you take to attempt to figure out the problem, do you go ahead and rip it apart and start cleaning? If cleaning doesn't work do you suggest to buy a new computer (offer data recovery, transfer, setup) because replacing the motherboard may or may not fix it and the price will just go up from there if its not the motherboard? What makes you decide if its worth the time, or when to call it quits on it?
This particular laptop the motherboard sells on ebay for $100+ while you can buy a used laptop for around $200-$500.
