HCHTech
- Pittsburgh, PA - USA
I have a customer that has a home-based consulting business. Their domain is hosted on GoDaddy, and they have a Comcast residential internet connection at their home. They have Outlook 2016, and they are popping email from their domain. The Servers in Outlook are pop.secureserver.net and smtpout.secureserver.net.
Just recently, the customer has started getting email bounced when they try to send to their biggest client - who happens to be Johnson & Johnson, believe it or not. The domain part of the recipient addresses is its.jnj.com. No other email is bouncing (so far, at least).
The bounce message says:
"Reason: There was an error while attempting to deliver your message with [Subject: "Redacted"] to redacted@its.jnj.com. MTA p3plsmtpa07-10.prod.phx3.secureserver.net received this response from the destination host IP - 68.232.149.99 - 554 , 554-esa18.jnj.iphmx.com
554 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error please contact the intended recipient via alternate means."
Attached to the bounce message is this details.txt file:
"Reporting-MTA: dns; p3plsmtpa07-10.prod.phx3.secureserver.net [173.201.192.229]
Received-From-MTA: dns; DESKTOPKK9DBAO [73.154.209.XXX]
Arrival-Date: Mon, 17 Jul 2017 08:46:45 -0700
Final-recipient: rfc822; redacted@its.jnj.com
Diagnostic-Code: smtp; 554-esa18.jnj.iphmx.com
Last-attempt-Date: Mon, 17 Jul 2017 08:47:16 -0700"
Ok, so I'm having trouble interpreting this enough to point the finger of blame appropriately. WHO'S MTA has a poor reputation, here? The "Received From" line in the details.txt file lists my customer's computer name, and an IP address that belongs to Comcast (73.154.209.XXX). If you lookup this IP on MX Toolbox's blacklist check, you'll see it on two blacklists. Ok, is that the end of the story? Her computer is clean, but maybe another household member's computer is sending spam? A quick trip to whatismyip.com on their computer returns only an IPv6 address, so that isn't exactly a slam-dunk.
Just for fun, I also looked up the IPv4 address from the details.txt file on Spamhaus's PBL list - I get:
"Ref: PBL1625004
73.154.0.0/16 is listed on the Policy Block List (PBL)
Outbound Email Policy of Comcast for this IP range:
Email sent by Comcast subscribers using a mail program such as Outlook Express are required to send the email through Comcast. To insure your mail program is properly configured, please visit http://www.comcast.net/help/faq/index.jsp?faq=Email117481. If you are a Comcast Commercial Services customer and need support, please contact support_biz@cable.comcast.com"
Which is basically saying (I think): This is a dynamic Comcast address. You are sending email over this connection but you are NOT using Comcast's email servers - so you are being a bad boy and you are on the list. Is that the real problem? Should I change Outlook to send mail out through Comcast servers? That feels a little kludgy.
Isn't the more important thing the sending mail server? Outgoing mail is being sent through smtpout.secureserver.net (GoDaddy), right?
So a couple of other facts. There are two MX records for the domain. The 0 record is smtp.secureserver.net, who's IP address is not on any blacklists. The 10 record is mailstore1.secureserver.net, who's IP address is listed on the spamcannibal blacklist. I don't think this is related to the bounce problem (MX is incoming mail), but I would think GoDaddy should be responsible for removing that secondary server from a blacklist.
Because it's never a bad thing, I have the customer running virus & malware scans on the other household computers, but I'm struggling to make a better plan of action.
"Ref: PBL1625004
