SmittenmittenS
- Colorado
Ubiquiti finally shipped the preorder we had on their newest WiFi system Amplifi. We did a test set up of the system and it worked great! We will be setting it up at client location tomorrow so can give a little more feedback then.
The setup for this device is so easy anyone can do it. Download the Amplifi App and it takes care of the rest. Simply plug in your device, turn on your wifi/bluetooth, open the app and the setup begins. It will locate your device. Select the device, it will ask for SSID/Password. Once you create the Network it handles the rest and you are in business.
Once connected in the app it will display the health of your device and all relevant information. You can then plug in the mesh adapters and after about a minute they will connect automatically. The app allows you to see any information about the device itself along with all connected devices, network speeds, and all options a standard home WiFi router would have. DHCP settings, Static Leases, Port Forwarding, Guest Networks. I know I am missing a few things but I already factory reset the device. All settings are controlled through the app. No computer, no browser, no direct connection. The app can also control LED and LCD settings for the Mesh Adapters and the Main Hub as well. I think the hardest part of the setup was finding the app on the Play Store. I was just searching Amplifi and it was saturated with Amplifier programs. Just searched for Amplifi Wifi and it came right up.
First impressions are good. The setup is easy. The range is pretty good. I walked throughout our entire office building and stayed connected 100%. I could never tell if I was on an extender or the actual hub, but running multiple speed tests the network speed almost always reached our wire speeds in office. I went to all corners of the building and even outside and the speeds never fluctuated.
Setting this up tomorrow in a multi level house. Will post back with updates on how it performs for the client.
