Jimmyb
- Tinley Park, IL
Do I understand correctly?
When I boot to a Windows PE disc (or UBCD4WIN) I by pass any and all OS on hard drives .. correct?
So if I pull the hard drives, NIC cards and any other non-essential devices, I should be able to boot to the disc. But in fact this PC only gets to about 20% and then sits there. I have tried swiping out RAM still no fix. Tried different Windows PEs and no fix.
It will boot to Windows OS with hard drive in, but then if I try to access USB drives it is so slow it is impossible. Was going to check the drive using the disc but now I cannot boot the Windows PE disc.
Do I assume I have a bad CPU? Any thoughts/ input?
