Did networking at a place where I had to use a very thing wire to get into some pipes. I also used uNifi accespoints that comes with poe-injector. The cable I used is used for network jacks rather than rj45 contacts but in this case I had to use contacts (ceiling mount).
When I had "contacted" two cables and tested them only 6 of the 8 conductors worked (5 and 6 did not work, suppose that's green and white/blue) however the access points worked fine (both the actual network traffic as well as the power from the poe-injector).
It might be something with the cable that the tester doesn't report as I find it strange that two cables should have the same non-working conductors. Or does unifi POE only require 6 conductors?
