Sky-Knight
- Arizona
Untangle 14.1 upgrades are sometimes breaking OpenVPN connectivity.
If you have OpenVPN clients reporting the following error: Bad LZO decompression header byte: 251 You're affected by the bug.
To fix it, get into Untangle's admin console, OpenVPN settings, advanced tab. In the Server Configuration section, check the exclude box on the "compress" line, then add a new line, option name is comp-lzo, leave the rest default, and save.
If you use OpenVPN to connect for administration, and cannot access the UI you can repair your own client settings by editing the .ovpn file in c:\program files\openvpn\config, find the comp-lzo line and change it to compress. Beware if you perform the above you'll have to change it back later.
Be further advised that the comp-lzo directive is deprecated, and the existence of it on your server means you need to delete the module, reconfigure it from scratch, and redeploy your VPN clients to get to a "current" configuration. This message should be enough to get you to where you can schedule this, instead of doing it via a mad panic. You're welcome!
I won't mention how many mad panics I had before I discovered the above for myself.
