I had a customer try to upgrade his CPU from a I3-6320 to an I7-7700. In the process of doing that he bent a lot of pins in the socket of the motherboard. It would turn on for about 30 seconds then turn off without any video. The motherboard is a Gigabyte GA H110M-S2H-GSM rev 1. It says on the website that the I7 7700 is a compatible CPU.
We ordered the same motherboard brand new from Newegg and I put the old I3 CPU back in and updated the bios to the latest version f25 and everything was working fine. I was able to login to his profile and had no problems.
I took out the old I3 and put back in the I7 and now it is back to doing the same thing. Turns on for about 30 seconds with no video and then shuts off. I took out the I7 and put the I3 back in and now that is not working either.
I took out the cmos battery to try and clear the bios settings but that didn't help. I looked at the I7 and it doesn't look damaged or bent. Is it possible that the CPU got damaged as well and it's better to get both a new motherboard and CPU instead? I don't want to just get another motherboard and then put in the I7 again and ruin that board as well.
