HCHTech
- Pittsburgh, PA - USA
I'm trying to diagnose a problem at one of my clients that has the micro form factor Optiplexes. They have Dell P-series 24" monitors, that have the 2 USB ports on the side of them. The monitors USB connection is "Type B". Does anyone know if the monitors supply their own power to the USB ports?
I've got a situation where things will work when plugged into the monitor, but not when plugged directly into the computer. This is an auto shop - they have a barcode scanner and a laser printer (both currently plugged into the monitor - which allows them to work). Otherwise, there is just keyboard & mouse plugged into the computer (which also work). Plugging in a flash drive to any of the unoccupied USB ports on the computer doesn't work - no recognition tone and no drive showing up in explorer or disk manager - as if they are not connected.
The original symptom was that the printer stopped working - and I haven't been onsite yet, but just talked them through some things to try. These are pretty new units, only a couple of months old. I'm wondering if those micro PCs have don't have enough juice, their power bricks are only 65W. Both the laser printer and scanner wand are old, so maybe something is at fault there as well. For now, plugging them into the monitor USB ports made them work, but if there is a problem with the computer itself, I don't want to wait before starting down that path. Something isn't right if the computer can't even detect a flash drive. We've got a couple of dozen of these microPCs out in the field - I hope this doesn't turn out to be one of their weaknesses...
