thecomputerguy
If all three are O365 accounts? I'd have to agree... What are those three accounts?
She has her email, the admin email, and another Lawyers email.
And all three of them are O365? Are they all on different tenants?
All O365, same domain, same tenant.
I was just logged into the computer while making all of the changes above and it again, stopped receiving mail, I did a CTRL click on the Outlook icon to check connection status and everything is connected. Once I hit reconnect emails started coming in again.
Ok, if you have THREE O365 logins on one outlook, all aimed at the same Tenant then... your client is correct you don't know WTF you're doing. But it's an easy thing to fix.
There should be ONE login, hers... then you go into O365's admin portal and you give her read and manage permissions on the other mailboxes, send as permissions if needed possibly. Outlook will populate all three mailboxes to her Outlook for you.
You should never have more than 1 login in Outlook aiming at the same O365 tenant, you have tools to handle that work, you need to use them.
Fix the permissions, nuke her outlook profile and have her login, it'll put everything back as a single managed entity.
Technically the multiple separate logins should work... but that's intended for multi-tenant access. I have no idea what a single Outlook being managed three times by the same rule set will do.
That is the proper way. Set up a single Outlook profile, give her full access to the other mail boxes. In Outlook under account settings, click the main email address, click change, add a mailbox, add the other 2 mailboxes there. When you do, it should put them as separate headings on the left side under the main set of folders. User should then be able to see all once they sync.
