virus scan (wrt speed), rouge antivirus, random
commentator8
Hi all.
Seems strange to be posting here, not having visited for a while, but it can be fun to talk to people who actually have a clue as to what you are talking about (as opposed to almost all customers)! I understand that this will be a very loosely connected post - so be it.
First off: AV scanners. I have browsed a few of the recent posts on what each persons personal preference was with regard to infected computers and procedure. Personally i will run rkill or taskkill, try and manually remove most visible parts of a virus (autoruns, task manager), then run a portable SAS and MBAM (had a computer at a house without internet recently and wasn't worth taking it back with me) in normal or safemode, and depending on the problem hijack this and tdsskiller. I will finally install MSE and run a scan.
Now - with regard to anti virus scans, most all ones i have tried are painfully slow. I have a copy of the AVG, GDATA, Kaspersky boot discs, UBCS, UBCD4WIN, falcon4/hirens, and other fun discs. All very slow. MSE isn't bad, but i had a fresh install the other day that somehow scanned almost 500,000 files. I believe most of it resided in the winsxs folder too. I heard mention in passing in a post that panda cloud is very fast. Is this true, and regardless, what AV is?!
And i still prefer in system scanning than taking out the hard drive and slaving it.
Next. With regard to rouge antivirus's: I have had 3 systems come in with dake antivirus's, all of which prevented opening anything (called it a virus and killed it), so task manager was out, msconfig... I inevitably ended up in safe mode (occasionally with the virus still running), and trying to disable it. Then i could start on eradicating it. One interesting point i saw was simply renaming the folder (generally in appdata or user/). This will stop it running the next reboot? Simple yet nice way to start. Any confirmation would be nice. (till the next system anyway).
Another point that may help people is something that i recently encountered on vista and 7 that took a while to figure out, but really helped. I had one computer (win 7) that installed some updates as a routine task and was shut down after seemingly stalling (finished updates in shutdown and hit black screen) and staying as a black screen for 3 min. Wouldn't boot (bsod 0x000000f4) nor would the windows disc help.
And if you have ever faced a problematic vista/7 with no restore points and a "startup repair" that ends with an error, microsoft have in their enormous wisdom decided to remove the repair windows from disc option. So if you get in a situation like this you are in trouble. I ended up being able to resuscitate it (exactly as it was, no loss) by running sfc. Which of course is sort of har without windows. You boot from the startup repair, choose cmd, and DONT run sfc /scannow. Rather you run sfc /scannow /offbootdir=c:\ /offwindir=c:\windows. For reasons you can google if you want (re running sfc from a image). Obviously this isn't a fix all, but a useful addition to the toolbox.
The other related issue was on vista. After beginning to install sp1, running through the full half hour then needing to reboot, it rebooted to a sp1 error "catastrophic error" and then to the startup repair screen. That went nowhere. The solution finally, after trying to fix it by restoring the registry, checking boot.ini, blah blah blah, was to delete everything in "Downloaded Program Files" and another similar sounding folder. The files for sp1 were preventing it from restarting and some error was preventing sp1 from continuing. Love the logic.
So hope that helps someone some day, as in xp the only luck i have ever had after beginning a system repair and having it fail midway has been to format/reinstall xp (except for one time with a dud PSU). It normally gets stuck in a loop. Albeit i haven't had that problem in a while.
Yup, most are. IMO the fastest scanner is Avira (they do a free linux live cd, but it doesn't clean infections; it renames the file extension or deletes them), seconded by ESET's Nod32.
Whilst it may be more time consuming or even difficult to slave the drive and scan it from another machine, it is often necessary due to infections being so dug in deep into the operating system that they can't be removed in normal mode or rootkits may be impossible to detect whilst they're active.
Renaming it would stop an infection in that folder from running at reboot, but I don't know what the repercussions of this would be (I know there's some MS data in there as well as other software data); best try it in a virtual machine first.
A common trick nowadays that can get some software to run it renaming it to a windows process (this assumes the fake antivirus has a white-list of known good process' (eg, explorer.exe)), such as 'svchost.exe'. By doing this, you might be able to get Process Explorer to run and then kill off that malware process. When I get an all exe blocking malware that I can't get past by renaming, I usually turn off the machine and boot from my winpe cd (although ubcd4win would be fine), load up Autoruns and load the offline registry hive and check for malware autostarts, then check the program files/programdata for suspicous entries, check the users' application data and all that, and then check the windows and system directories for malware by sorting by date to find new infections (I know, creation/modified data can be faked, but it's way beyond most infections).
So this is in large what i do as well, but if i can turn it off straight away that can save a step. I like the idea of renaming to explorer.exe etc. The reason for not slaving it is so that all traces are removed. But if need be i have the hardware to slave a drive. Nod32 isn't free is it (?) so it wouldn't work for a temp install on a customers comp.
Another thread recommended either panda cloud or hitman pro 3.5. I haven't used avira in a while though. Any opinion on the three (which is fastest/thorough)?
As to renaming "it" i was referring to the folder the virus created, not the whole appdata folder. try deleting appdata/roaming or local and there goes all your programs if not the comp. But generally the fake antivirus's put themselves in folders there with names made up of random letters.
