Hi everyone,
I have a very weird display issue on a 15" MacBook Pro Retina A1398.
This MacBook had liquid damage. I got it for free and attempted to save it.
I looked at the motherboard under the stereomicroscope and cleaned it with isopropanol.
On the mainboard, one choke capacitor is rusted. Apart from that most components are visually fine.
The cleaning was done some time ago, but I remember there was very little verdigris if any.
Symptoms
- MacBook powers on with the bell.
- Pattern with horizontal stripes on the screen, however the Apple logo is perfectly pictured, at least at the beginning ; then stome stripes overlay it.
- Running a live Linux from an USB flash drive partly works. The graphics get tiles four times vertically (like a mosaic) and the OS gets stucked at some point.
- Running Apple High Sierra installer from an USB flash drive partly works ; the installer gest stucked at some point.
- If removing screen and connecting in HDMI to an external screen, the HDMI signal is detected but unfortunately out of range of my WUXGA (1920x1200) screen.
Although I could not test if the problem remains on an external monitor, I assume the screen is OK and the problem coming from the motherboard.
Else, the operating system would go on and the output would likely autoadjust to the external screen resolution.
I also assume the LVDS is OK as it does not seem damaged.
To my opinion, the problem most likely comes from the GPU or the processor, and maybe the GPU's VRAM or some cache.
But the problem could also be located at the RAM chips.
Or some other defective component.
I wonder if the symptoms (please see attached pictures) are typical from some kind of failure.
This is a technical thread, not one about profitability or hardware alternatives. Thank you.
Symptoms
