lcoughey
- Ontario, Canada
Let's preface with the fact that I have at least 6 Windows 10 Pro systems that work without issue.
We just replaced a 6 year old Acer laptop that was running Windows 10 Pro 32bit right up last week. But, the display stopped working and we figured it might be time to replace the unit. Bought another cheap Acer laptop, pre-installed with Windows 10 Home.
Forgetting that the old laptop was running 32 bit, went through the process of moving the SSD over to the new laptop and it was working fine, with the exception of the 32 bit and not accessing the 8GB of RAM. Knowing how easy it is to install a fresh copy of Windows 10, I did a complete fresh install on the system, thinking that I would be prompted to install pro, but it installed home.
No worries, just did the windows 10 pro upgrade via the Microsoft store. Joined the domain, added the user as an administrator, rebooted and bam! We get a message that the password is incorrect. Weird. Even went as far as resetting the password on the server, just to be sure we are using the correct password.
When I go to Computer Management, the Users and Groups snap-on isn't showing by default, which is odd, as it shows by default on all my other Windows 10 Pro systems.
So, I've re-installed Windows 10 several times, looking for a prompt for pro, but none has been given. I think I have figured that out, by entering the generic windows pro key, which matches the key that shows when I upgraded to pro via the store.
But, assuming that I will still have issues with the domain login issues, I thought I'd ask if anyone has encountered this and what was the solution? If it were a security setting on my server, I'd think that none of my windows 10 systems would work, though I must admit that the others were all upgrades from windows 7 pro or windows 8.1 pro.
Any suggestions?
Any suggestions?
