I'm having some trouble with a client's file sharing setup.
3 PCs, 2 of them new Dell Optiplex running Win7 Pro, one older HP all in one running win7 Home Prem.
They have an Access database shared from the Main PC which is one of the Dell systems. For some reason the Access database programmer set it up in such a way that the only way for it to work is if they shared the entire Users subfolder to the other machines.
The Dell systems came with Mcafee preinstalled for a year, so I left it on there (Otherwise, would have installed Kaspersky or ESET), while the HP has MSSE.
Every few days they would call me with issues accessing the network share where the Access database resides.
All usernames and passwords for the 3 machines are identical so I shouldn't have any issues with asking for a username and password when trying to access the share. I set the Network to a Work Network and allowed file sharing etc, checked permissions and everything is set correctly.
It worked for a while, then after a few days when they try to access the shared folder it asks for the username and password. Verified they're using the same username as on the Main PC.
I disabled the mcafee firewall and that helped for a few days. Now the same problem occurs. Firewall still off.
I turned off password protected sharing in the Advanced Sharing Settings, rebooted, no change. Changed 128 bit file sharing to the lower setting, no change. Gave Everyone full control in the advanced permissions area, no change.
I uninstalled Mcafee from both machines (installed MSSE temporarily) and now the second Dell system can access the share, but the old HP AIO still asks for a username and password.
The only difference between the machines is that the HP is running Win7 Home Premium while the others have Professional, but this should not really make a difference.
The only thing I can still think to try is to change the Network to Home and set up a Homegroup, but I feel this is a cop-out.
Before I go over there tomorrow to sort this out, can anybody throw out some ideas to try to get this to work correctly?
Thanks in advance.
Thanks in advance.
