ohio_grad_06
Ok. I give. I usually am better am a better tech than this but where to begin. So I get a call to look at a machine saying basically the computer will not start. Windows 8. Yeck! Get onsite, realized it is a windows 8 PC, didn't really have a lot with me, but had my handy Parted Magic cd with me. I've worked some with Windows 8 before, but only on my personal PC, or training users hwo to use it. Not actually repairing, reinstalling as of yet. In the last year or two, I've had 5 or so people even ask about it. The couple I have had for repairs were simple virus cleanups not big deals.
So I get there, and this thing is in a boot loop. IE it won't start, it keeps diagnosing the PC, and then it attempts to perform a repair, which it is unable to do and so it reboots, attempts to diagnose the PC, etc etc and the process continues on and on and on.
Did the following.
1. Go into bios and disabled secure boot, disable fast boot options.
2. Booted from parted magic usb stick which gives me the gui works ok. I run a quick test of gsmartcontrol on the hard drive which comes back with no errors. So one would think the drive is ok.
3. Here's where life gets interesting. I attempt to look at the partitions, which I can see a recovery partition, and parted magic allows me to look at that ok great. But cannot view the OS partition. I can see it's there, but unable to mount it. Being it's late, I tell the user let me take it back with me and look at it some more and do some research.
4. Only Windows 8 discs I have are Windows 8 Pro upgrade discs which I bought to upgrade my system with. Couldn't get the machine to safe mode, so I figured well I'll boot from my disk. I boot from my Windows 8 pro upgrade discs, it won't boot the 32 bit OS disk, it will boot the 64 bit.
5. I booted up, tried to do advanced options, and have it do automatic repair. If I do automatic repair, it goes back into the boot loop.
6. Attempted system restore, but no restore points found.
7. Getting interesting. I attempt to do a system refresh(the option that just deletes the apps and leaves the files), however I get a message that the disk is locked.
8. I'm remiss to do the reset option where it just deletes everything, give the machine to the client and say sorry had to blow it away.
9. Downloaded the Windows 8 PE cd listed in the forums, though I had a copy before, started the machine from that, and it works, I had read in the forums something about you may need to slave some of these windows 8 drives to another pc to run checkdisk, so I attempted to do it from the cd, which I get a message about not being able to access the disk.
I downloaded rweverything portable, and attempted to read the windows 8 key from the bios. Unsure if the version is Windows 8 or Windows 8.1. User states that the computer is about 1.5 years old. So my guess is Windows 8, but not sure if he did the upgrade to 8.1. Also it's a cheaper home grade system, so should not be the pro version.
I know Windows 8.1 started doing disk encryption by default, wondering if this is why I can't see the hard files.
Here is where the rubber meets the road.
a. I can boot from other discs, including Windows 8 PE, so the hardware is at some level functional and working correctly.
b. GSmart Control says the hard drive is good. I can look in the Disk Management screen under Computer Management-->Disk Management in the Admin tools section of the Windows 8 PE disc, it says it sees C drive and that's it's healthy.
c. If I try to access the C drive from the Windows 8 PE cd, it tells me the file system is corrupted. If I try to run checkdisk I'm told I can't because the drive is not accessible.
I pulled what I think is the Windows 8 SN and I have the users login info for their MS live account which they provided. I also have a spare hard drive that I can test with.
However, I don't have any Windows 8 discs other than my Windows 8 Pro upgrades.
I tried to track down Windows 8 trials, but they seem to be for enterprise, and for Windows 8.1. Is there a way to obtain legally discs for Windows 8 or 8.1? Also do you believe the hard drive is actually bad though reported good? Corrupted maybe or encrypted? If encrypted, game over most likely for the file recovery.
Sorry for the long post. Just trying to do some digging and frustrated. Windows 8. BAH!!! Can't wait till MS gets rid of 8.
Did the following.
