Mick
- Cambridge, UK
A few months ago, we installed a Windows Essentials 2012 server for a small local business, with seven PCs as clients running Win 7 Pro 64 bit. The server is acting as a DC. We successfully joined all the PCs to the network using the built-in Windows Connector software. A week ago, I noticed on a routine check that one of the PCs had disappeared from the Windows server dashboard, although it was still showing everywhere else (explorer etc) as being available and on-line and the user was able to log-in without problems and do all the usual stuff like access their own folder on the server, surf the net and so on.
I've been trying, unsuccessfully, to rejoin this machine to the server. I've taken the PC off the domain and parked it in a workgroup. Then I've uninstalled the connector software through Control Panel and also removed the computer from AD on the server. Trying to rejoin using the Connector software and an internal browser link - all as per MS's recommendations - has failed. The Connector software starts to run and gets as far as asking for account credentials. When I input these, using a domain admin account, I get "Connector software is unable to continue. An unknown error has occurred." This has happened time after time and I seems clear that I am not going to get anywhere merely by repeating the process. The PC's event log just shows 'an unknown error' has occurred. I can manually join the PC to the network (simply by reversing the process described earlier, i.e removing it from a workgroup and making it a domain member) and that works OK, but the PC still won't show in the server dashboard. And, because of that, we are not able to remote into it, neither is it included in scheduled back-ups. I have a feeling that the connector software is not properly uninstalling, although I haven't been able to verify this. If anyone has any suggestions for what we try next I'd like to hear from them.
