I need this for a client. Their new server is not compatible with older software, so I need to install Server 2003 or (if I have to) 2008 on a virtual desktop to run old software on. I need a good, reliable source to get it, 10 CALs and any advice for trouble I may run into running a server on a server, especially installation.
Note, NO OEM version. It's a violation of the license agreement to install an OEM version on anything but new hardware. I want it all above board and legal.
It must be 32 bit, I prefer 2003, Standard edition is fine, need 5 CALs for sure, maybe 10 if they're cheap. I want this as cheap as possible, but more importantly, legitimate and legal.
The server it will go on is Windows Server 2012 R2 Standard with Hyper-V installed. It has 32GB of RAM installed and its only other function is shared drives with backup. Instead of a domain, which the customer had, but never did function right (that wasn't me), I went with user-level access to shared directories with a matching username/password on the server to that on each PC. (Believe it or not, this is actually more secure than what they had set up before. They didn't need to actually log into the domain to get to the shared folders, which had write access for "everyone". I'm not sure what their last guy was thinking, but the domain did absolutely nothing for them as he just used shared folders with no security anyway. But beside the point.)
So, I need a reliable, inexpensive source for a Server license, disks and CALs. Everything I need to pop in the disks and install it on Hyper-V as a "second server" with 8GB of RAM.
One last thing, hacking is a concern here, especially with an OS this old. In the client's mind, the server it's installed on is new and safe, so this will be too, but I know that's not the case. This will actually be a server with an older OS on it, connected to the Internet. Is there any way to not forward incoming traffic to it that is not part of a connection set up by software on the server? For instance, if I start downloading something over FTP, software on the server initiated that and it contains much incoming traffic. But if I do a port scan from my office, that's not associated with any outgoing connections from the server. Not sure, but I think the technical term for what I'm asking for here might be "magic". But with an OS too old to put modern antivirus on (short-term, maybe, but long-term, less likely) I need to do something.
