Question...is all this still true?
"After you’ve installed Windows 10 without a key, it won’t actually be activated. However, an unactivated version of Windows 10 doesn’t have many restrictions. With Windows XP, Microsoft actually used Windows Genuine Advantage (WGA) to disable access to your computer. These days, Windows just complains at you in a few minor, cosmetic ways. Initially, you won’t notice a difference. Eventually, Windows will start nagging you a tiny bit. First, you’ll notice a watermark in the bottom-right corner of your screen. You’ll also see a “Windows isn’t activated. Activate Windows now.” link at the bottom of the Settings app. This is the only form of nag you’ll see–there are no pop-up windows, for example.
Aside from these basic limitations, your Windows 10 system will continue to work forever. There are no nag prompts aside from the watermark, you’ll get all the system updates, and everything else is completely functional. The only thing that could change this is a Windows 10 update, but Microsoft has become increasingly lenient since Windows 7."
http://www.howtogeek.com/244678/you-dont-need-a-product-key-to-install-and-use-windows-10/
