B Trevathan
- Tennessee, USA
Help I can't get past this stop error and I'm just looking at the computer so I can give the customer an estimate on the cost to fix it. Sorry for being so long but I wanted to list the machine and OS that I'm working on and and the error and what I have done to try and fix it.
I've got a Dell Dimension 4600 running Windows XP Home edition that is giving a 0x0000007E error in normal mode, all safe modes and also with last known good configuration. It doesn't list any files in the stop error. The error is happening after the XP logo comes up and the status bar runs across the screen for a good bit.
The customer told me that his son in law may have done something to the computer and that the son in law thinks that he is a computer guru. The customer said that his son in law was always installing different AVs, he said that one week he would install one and then the next week someone would tell him about another so he would install that one, I told him it is bad to have two AVs running.
So with the information about more than one AV running I thought that the services would be a good place to start, I loaded the recovery console and listed the services and found two AVs services running, Avira and AVG. I disabled the Avira Services and restarted and the computer did a check disk and repaired some errors ( Pagefile and some AVG files) then the computer restarted and gave the same stop error 0x0000007E
So next I loaded the recovery console and disabled the AVG services, but still got the same stop error on restart. So I'm think maybe a virus got through while the AVs were conflicting with each other so I ran an AV live CD and found several malware but nothing that looked like it would keep Windows from loading, mostly Java viruses.
Now I started think maybe its a bad update or one like the KB977165 update that caused some 0x0000007E stop errors about a year ago. Checked updates but no recent updates most where dated before 11/11/10 and no sign of update KB977165.
So I'm thinking maybe a bad drive so I run Dells IDE drive diagnostics from the Boot device menu and it passes so I run chkdsk it says “The volume appears to be in good condition and was not checked. Use /p if you want to check the volume anyway” so I ran chkdsk /p and chkdsk says found one or more errors, so I ran chkdsk /r and chkdsk runs and the computer restarts with the same stop error. Each time I run chkdsk I get the same thing. I used UBCD4Win and checked the health of the drive and everything looks good.
So I'm thinking maybe its bad RAM causing the stop error when the Windows GUI loads or cause problems when chkdsk is moving things around although I haven't had any problems running live CDs like UBCD4Win, but I run checks on the memory anyway. I used Memtest86+ and Memtest86 and Windows memory diagnostics, but everything passed. I tested both sticks at the same time because I'm just looking at the computer and the computer has a whole lot of dust in it. I looked at the caps while I had the case open and the ones that I could see all look good.
Any ideas on how to fix this stop error?
