B Trevathan
- Tennessee, USA
I don't know if this information will help anybody but I ran DSRFIX and this is what it showed:
Disk 80 found, master device at port 01F0
48-bit user secs : 156250000 (80 GB)
48-bit max secs : 156250000 (80 GB)
i13/48 use secs : 156250000 (80 GB)
disk clys/hds/secs : 9726/255/63
alert : boot code does not match dell mbr.
good : pbr descriptor 1 is type DE.
good : pbr descriptor 2 is type 07.
alert : pbr descriptor 3 is type 00, not DB.
info : pbr descriptor 4 is type 00.
good : pbr1 is fat16, label is DellUtility.
fatal : pbr3 is not fat32.
alert : reference partition table not in sync.
From the Dsrfix instructions:
Good: These are characteristics that will pass DSRcheck's review.
Alerts: These characteristics will cause DSRcheck to fail, but are relatively easy to fix.
Fatal: These characteristics will cause DSRcheck to fail, but are not easily fixed.
Info: These characteristics are not relevant to DSRcheck, but can help the user analyze his/her system.
Every time I try to boot to the Dell Utility partition it just tries to load Windows.
I also run PTEDIT and this is what it showed:
PowerQuest Partition Table Editor
Hard Disk : Drive 1 (76293MB) 9726 cyl, 256 heads, 63 sectors per track
Type Boot Starting: Cyl Head Sector Ending: Cyl Head Sector Sectors: Before After
1. DE 00 0 1 1 3 254 63 63 64197
2. 07 80 4 0 1 1023 254 63 64260 15676785
3. 00 00 0 0 0 0 0 0 0 0
4. 00 00 0 0 0 0 0 0 0 0
Partition Information
,31 MB
,31 MB
