Markverhyden
- Raleigh, NC
I recently installed a modem for my client after their previous one was lost in a power surge. Before this, another tech installed an AP to boost the signal so it could be picked up in another part of the house. I now need to login to the AP in order to update the settings so it will work with the new modem. The problem now is I can't login to it, even after resetting it a bunch of times. Either the previous tech changed the default IP or the AP is buggered. Model is a Planet WAP-4036. Website says the default IP should be 192.168.1.1 , but it does not work, I've tried lots of other IPs in this range with no luck. Any ideas?
You can leave it hooked up to the network. Hook up a computer to the network that has Wireshark installed. Monitor the traffic looking for a private IP address that is different. You can also grab the MAC address off of the device and filter the traffic for that value.
