eggy53
- Puerto Rico
I have a customer laptop with intermitent black and sometimes pink screen. First thing that came to my mind was inverter, but I replace it without luck. What do you guys think could be?
does it do it on ext monitor?
does it do it at boot as well as in windoze?
does it do it when hinge is moved?
have you swapped out panel to eliminate that?
Did you check cable seating?
Were you able to swap out cable with known good unit?
- it would really help when asking for technical assistance to provide a proper synopsis of what you have tried. There are some fundamental bases to cover here and "I swapped out the inverter" doesnt give much indication of your thinking or what has been eliminated as a possible cause so far.
He means did you change the LCD screen. What does the external display look like? The backlight blub could be blown that would account for it being dark but not pink. I'd say if it displays okay on an external then your looking at a bad LCD or ribbon cable. I'd lean more towards the screen itself since opening and closing the screen doesn't do anything different. Nor have I seen a bum cable that causes the screen to be dark but visible.
Nope I didnt change the screen. On the ext monitor the image looks perfectly normal. Also the pink color start as a mid dark pink and start disolving into normal color.
