Any reason why not to buy this CPU?
joydivision
Manchester, UK
I have an old AM2 motherboard out of an old acer I bought for £200 brand new back in Jan 2007. It was cheaper to buy the PC ready made than it was to build a new one at the time as I had an old Socket A Athlon XP 2000 system which was well past its best.
The current PC is very different from that £200 Acer and is in a decent case etc. I run a now old 8600 GT and an expensive audiophile sound card.
My motherboard has a fault which requires several attempts to boot and I am getting sick of it. The 4200 X2 CPU I now have (upgraded from the original Acer sempron) is also showing its age.
I have seen this Quad Core AMD for £61 but it is out dated socket AM2+ but I have seen AM2+ boards which support both DDR2 and DDR3 ram allowing me to continue using my old DDR2 and upgrade to DDR3 at a later date.
The problem is the CPU above means buying an AM2+ board (which will support AM3 chips). Apart from limited upgrade potentials are there pitfalls with this? The way I am seeing it is the upgrade will cost me £100 and I will go from having 4200 X2 to a 9850 Quad.
Am I missing something?
http://www.microdirect.co.uk/Home/Product/48253/AMD-CPU-AM2--9850-Phenom-64-Quad-core-oem-AM2-
I dont think there's much difference in performance in a desktop machine going from ddr2 to 3 so in that regard the ram recycling is a good way to go. I do wonder about money on an outdated cpu though.
Personally, Id have a look at the average sale price of the parts I had on Ebay and do the maths on what an upgrade to current parts would be.
In my experience when building on a budget its often not much if a stretch to sell parts and go with a more current build.
The quad is only useful for apps that can use all the cores. I think you would find a quick current gen dual core would beat it easily for general desktop work. Current gen quad like a 955 would gazump it completely on anything that can utilise all cores, as its several generations old.
Out of my 3 most used systems I am still using 2 AMD 2800+ CPU's and a Pentium D dual core. They work fine. However, i built an AMD quad core about a month ago and loaded OpenSUSE 11.3 on it and it was smokin fast. Its to bad I had to put Win7 Pro on it for the customer :-(. Not sure if the modern Linux kernal takes more advantage of the quad cores or not but it was unbelievable smooth and responsive. I have never seen KDE4's affects operate so smooth. Because of that system I have been thinking about upgrading.
I think my point is does it matter if it is a few generations old as I won't be upgrading the CPU with that board anyway. I would want USB 3.0 though.
I recently built a Athlon II X2 250 based system for a friend. Even though that CPU is considered low-end (for current AMD CPUs), it still had plenty of pep. I mean, you can buy a Phenom II X4 for $150 or so, an Athlon II X4 for like $100 or so, and a decent motherboard from gigabyte or ASUS for $100 or so. So, mobo + CPU is only a $200-250 upgrade. DDR3 isn't that bad either right now, you can get 4 GB for like $80 if you shop around.
And if it's any consolation, I'm still running a Pentium D in my main desktop/business machine. :) Works pretty well...but I'm planning to upgrade to an AMD based system sometime.
I know Intel is winning in terms of performance but do AMD still offer the best band per buck? I have been very impressed with the new low end Althlon CPUs.
The machines I have built over the last year have all tended to be Intel 775 but for personal use I am still a massive AMD fan. All personal desktops in this house are AMD AM2s.
Yes. Absolutely. The current AMD cpus are better performance:dollar ratio than Intel.
(Im not a Fanboi of either. This is just the current state of play between the two manufacturers in this generation of cpus)
bang per buck, always AMD
absolute performance, still Intel.
DDR3 ram prices is dropping like flies. but DDR2 haven't. maybe you should run some build and estimate the costs.
