I'm trying to upgrade a SONY VAIO AIO model number SVT21213CXB from a very slow, possibly defective, Toshiba 500 GB spinner to a Crucial BX500 240 GB SSD. Downloaded the Acronis transfer software from the Crucial website, and ran it. It completed without error.
Installed SSD, system boots (quicky!) and runs fine for 2 - 5 minutes and then shuts off. No blue screen or any error indicator, it just turns itself off. Booted several times - same thing. Can't check event log for errors as it won't stay running long enough.
Removed the SSD and put it in my USB dock station connected to my bench machine. Chkdsk fixed a bunch of errors. sfc /scannow ran clean.
Put it back in the AIO, same issue.
Put the original HD back in, runs fine no problems (other than very slow). Put the SSD back in, shuts off after 2 - 5 minutes.
The original HD has Win 8.1 on it as does the cloned SSD. Since this wasn't working, I tried to install Win 10 1909 using a USB stick that has been used many times before without a problem. Part way through install, system turns itself off. ARRRRRGH!!!!!!
So, do I blame the SSD and return it? Is this particular machine not compatible with an SSD? Other suggestions?
Mahalo,
Harry Z
Mahalo,
Harry Z
