alexsmith2709
- UK
I've got a frustrating one today.
On every boot i get a BSOD with code SYSTEM_THREAD_EXCEPTION_NOT_HANDLED. No dump file is written so i cant analyse that to find the cause. After the BSOD it reboots and get the error 0xc0000001 error. User reported it failed an update before and last thing they saw was it "cleaning up" after the failed update.
srtTrail.txt from the automatic attempt to fix suggests the root cause is "A recently served boot binary is corrupt"
I cant boot to safe mode, but can get to recovery using a Win 10 boot USB. No restore points exist. I was able to remove a pending update from today but nothing from the previous update time of 17th.
I have tried bootrec /fixboot and get access denied error. If i try a bootrec /scanos or /rebuildbcd it doesnt find any installations. I have formatted the EFI partition and remade it with the files and no change to the errors.
I couldnt initially run sfc /scannow due to a pending repair, but removing the "pending.xml" from c:\windows\WinSxS" folder allowed me to run that and it found no errors. I have tried running DISM RestoreHealth, which completes but doesnt affect the result.
HDD seems fine, I ran memtest for a couple hours with nothing found, i know ideally i should run this longer but im fairly confident its not a RAM issue as i can run recovery or WinPE for hours without issue.
Before i nuke it, have i missed anything?
