Martyn
- Bedfordshire UK
I assumed he was talking about the DHCP client service on the computer.
ok just reread his post
Hi Folks
If I start the dhcp service manually then the laptop will automatically get an ip address from the router.
I don't think a static ip will help if the dhcp service won't automatically start with Windows.
Thanks
James
I'm lost because of his quote. If he sets a static ip then it should work
Do you understand what DHCP is? A static IP address doesn't require a dhcp service, because it doesn't use DHCP...I don't think a static ip will help if the dhcp service won't automatically start with Windows.
Or just give to computer to someone who knows what they are doing. If the OP doesn't understand the basics he shouldn't be taking on paid work.Workaround?
Give him a desktop shortcut with: net start dhcp in it, OR just put that shortcut into the Startup folder. Or, as I said a few days ago, go with a static IP.
Which is a fair indication this wasn't a hardware fault. In replacing the mainboard the OS would have been nuked'n' paved which is why it appeared to be the fix.* Statically assigned an IP. It would work for a few mins then stop.
Thanks for all your ideas.
Laptop is XP and set to get DHCP.
Drivers and device manager fine.
10 years exp in IT, yeah I know I'm rusty. Spent 6 years having guys do this type of thing for me.
Another laptop will connect to original router fine.
It has to be the laptop.
Question is, if I reload Laptop back to factory will this problem end?
Thanks
James
Also verify DHCP service is started in services.msc.
Thanks for your replies guys.
Basically the DHCP service is not starting automatically.
If I start it manually then all is good.
Thanks
James
Sounds like you're trying to help him.I'm not sure why people are still trying to help him troubleshoot this when he has isolated the problem. The issue is with the "DHCP Client" service not starting automatically. Hard coding is hardly a solution, more of a bandaid.
I'm going to assume you already made sure the Service startup type was set to: Automatic correct?
In this situation i'd most likely do the following
1. Verify service startup type is set to automatic
2. Check dependencies(CMD /K SC QC DHCP)
3. Run TDSSKiller
4. See if afd.sys, tcpip.sys, or netbt.sys are corrupted, replace and do a winsock tcp/ip fix
5. Repair install
I'd be willing to bet TDSSKiller will find something and resolve your issue.
IMHO, I very much doubt it's malware, most malware & virus writers want to keep the connection alive.
This type of problem is typical of malfunctioning security software and/or a corrupted protocol stack.
Thanks
James
Do I hear an echo?????????
