shamrin
- Lexington, Ky
A customer came in with a laptop that had a spill on it. The computer appears to work and, in fact, the keyboard had worked for a while then stopped. This looked like a normal replace-the-keyboard-everyone-is-thrilled job. After replacing the keyboard however, it still did not work - exactly. I've found that if I hold a key down for a long time, the keypress will produce the correct letter and continuing to hold it will fire off a character about once a second or two. Plugging in an external USB keyboard gives the same result. The on-screen keyboard works fine.
This is a Windows problem because the keyboard works fine in BIOS and using a Linux Live disc. The computer had a few virus issues which I've cleaned up now (perhaps there is/was a keylogger hanging around somewhere?). Safe mode, normal mode, same problem. Everything looks reasonable in the device manager, no missing or broken devices. I've uninstalled the keyboard drivers and let them re-install.
The "feel" is like the machine is at 100% usage and just can't pay attention to the keyboard but that's not reflected in the task manager.
All ideas welcome.
All ideas welcome.
