ohio_grad_06
Hey folks, what's up? I have a client who brought in a gaming pc, fairly simple.
AMD FX 8350
Board was originally an ASRock 970 extreme 4 with 4+1 power phasing and not much cooling on the vrm's.
8gb gskill ddr3 pc2400
1tb Western Digital drive
Raidmax ACX 700 watt power supply(25 amps on 2 12v+ rails)
Geforce GTX 760
DIYPC case similar to this one. http://www.newegg.com/Product/Product.aspx?Item=N82E16811353026
Client brought it in, saying it would freeze after about 30 minutes. Ok. Fired it up, opened up a temp monitoring program, yep, cpu seemed to be overheating. Told client let's get a new board as the 4+1 power phasing on the board is not great anyway.
Upgraded board to a Gigabyte 990FXA-UD3. Has 8+2 power phasing, should be a bit more suitable for the 8350 which is a 125 watt cpu.
Also went with an upgraded cpu cooler. I got this one. Thankfully I do most shopping at Microcenter, so got this for about 30 bucks. Normally, I would have reached for the cooler master hyper 212 evo, but the case is not wide enough and it would not have fit.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103084
So we got the old board pulled, put the new one in. Install the cpu, paste with arctic silver 5, install the new cooler, have everything as cable managed as it can be. Go to reinstall windows, few minutes later during the copy, bam. Lock up and blue screen. Ok. Restart, back to bios, set to optimized defaults. System runs for about 45 minutes, and bam locks up.
Keep in mind, new board and cpu cooler. Bad thing on this case is size, and only 2 fans. Which I'm not sure how good they are. Say to myself is this heat related? I pull over a desk fan, turn it full blast, and run a 5 pass intel cpu burn test.
That works fine. I'm then able to work normally with the side of the case off and the fan blowing inside. Monitoring temps in the background. Right now I've got the side of the case off, fan off. Things are running fine it seems.
Ran memtest 86 and that seemed ok, may need to do a longer run on that. Ran gsmart control on a short test and the drive seems healthy. As I said, it showed fine with intel cpu burn. So it seems now when both sides are on, it's possibly overheating. Thinking maybe upgrade the rear exhaust fan, and install a couple of pci slot cooling fans, as literally, there is no other place for fans in that case.
Thoughts?
AMD FX 8350
Geforce GTX 760
Thoughts?
