Cloned Drive Outlook (this computer only) issue.
lan101
I cloned a drive a week or so ago in a dell 3020 optiplex. Original drive was failing, but AOMEI backupper successfully cloned to a new samsung evo SSD.
Everything is fantastic other than on outlook 365...the contacts and calendar where it's (this computer only) Nothing is there now.
In the other contact folder there's like 40 or so contacts in there (but of course none of those are the important ones)
I know how that's an OST file etc. I know about that info but why wouldn't that move over correctly in a clone when everything else is working perfectly fine?
I figure there's probably some outlook snafu that I don't know about lol. It is an imap account as well.
The office account appears to be signed in and synced ok from what I can tell...I thought maybe there was a syncing issue but from everything I read that OST file shouldn't be syncing to anything.
The old drive is still available (although in failing stages) Is there a good manual method guide on that? I've googled and read various stuff but didn't find anything really concrete to me (but I am an idiot when it comes to outlook lol).
@callthatgirl
Thank you.
It's a 365 Outlook? Using M365 services?
There's nothing to fix... you open the control panel, fire up the mail applet, make a new Outlook profile, set it as default and open Outlook again. It configures itself to the M365 account as new, and assuming everything just works you're out the door.
For my managed customers I don't even bother to keep the old profile around, I just nuke it and start over. The only reason to keep an Outlook profile around is old bad habits. BUT in an unknown or potentially unknown situation removing the old profile is bad, because it'll remove files you might need to build the new one.
The email address is whatever@sagepointadvisor.com
Setup as an imap account.
It's just a personal office 365 account setup for the "office account" That's using a "gmail account"
So yeah everything works fine just no contacts and no calendar info for some reason. Doesn't make sense to me.
Makes perfect sense to me. IMAP doesn't support contacts or calendars.
That part I get...I guess I never realized on a clone that it wouldn't bring that info over.
I see on this link here that mention a better solution when setting up.
So since there's no "pop" account I assume it's just a lost cause then?
Thank you.
Well you said it yourself the drive was failing. If this was a 100% clone and the source wasn't damaged then you should 100% have everything in Outlook.
Exactly so maybe that's the deal. Maybe something slightly botched. As far as I know everything else is perfect on it.
Did you see what was in Outlook before you cloned, or hooked the old drive up to see what is in Outlook?
Nope I didn't unfortunately. They have the old drive though...so I'm willing to hook that back up to check...but if that info is there.....is there a way to export that out? Looks like there's some sort of .pst conversion you can do from what I read.
Looks easy enough to do from this video here.
Looks like hooking the old drive up would be the best option to see if the data shows up correctly there...then by following this video we should be good assuming to corruption lol.
Yes, if you can fire up the old drive and get Outlook to load, you can either export the contacts, or you can even just create a new folder on an external thumb drive and drag and drop the contacts there, then drag and drop them back into Outlook on the new drive.
Isn't the "On this computer" stuff in a local PST? It sounds like you just didn't transfer that file.
The way I read they changed that from Outlook 2013 and beyond...you can change it to .pst by following that short video I posted.
Yep that's what I'm thinking. It booted fine before just slow as a snail. I believe Outlook still worked fine...So I'll give that a shot assuming they want me to.
Still need help? My email alerts aren't working. @lan101
I'm not sure if they are going to have me check it or not. They were tied up for the next week or 2. Open to any further suggestions. I'm still curious if the original drive showed the contacts, but I still don't know the answer to that lol.
I'll post back if they have me check it out. Thank you.
