Sky-Knight
- Arizona
@frase That makes sense, the only application I've stuffed an M.2 that will see that sort of abuse is into a server, and in those cases the M.2s were in a drive bay designed for the purpose... IE fans moving buckets of air.
But yeah, I can see if a case has insufficient ventilation you might need something. The darned things tolerate up to 70C without fuss, which is pretty hot! I don't like anything getting above 70C EVER... but the new GPUs and CPUs are making me stretch that a bit. Especially AMD's APUS!
@Larry Sabo Of course it does! There's no fans in there! IF you you want a chip that can hit 70C under load to not melt when there's no airflow, you're going to need a heat sink! That application makes perfect sense.
