Did my first DC Jack repair today, didn't expect it to work but it worked perfectly well
However, as you may expect, it took a hell of a lot of time. Was just wondering about the kit I'm using:
http://www.proskit.com.tw/en/product/product_detail.asp?itemid=1PK-SC109B#spec
... with the 9SC116-SB standard tip.
The de-soldering process took the most, as there was practically no soldering on this Compaq DC jack, the soldering wick didn't pick anything. The soldering took only a minute but had an issue (which I believe is due to lack of experience) that soldering was getting attracted to the soldering tip rather than to the DC jack points.
Another problem was the the DJ jack takes a 5.5*2.5 adapter while the original took a 4.8*1.7
