The PC Resort
A friend from my day job brought in his Inspiron 1501 laptop and asks if I can do anything to fix it. He says that before he realized it wasn't charging, the battery went dead.
I did a little research on the 1501 at home. I removed the battery, held down the power button for about 30 seconds and plugged in his power adapter to see if I could get anything. Nothing lit up at all.
I didn't have another Dell power adapter, but I plugged in a universal (with correct settings) I have used on other units including Dells, and still got nothing.
Externally I checked the power adapter plug and it seemed OK, so I opened it up down to the MB and checked the adapter. The solder joints look and feel OK so at the moment I am not thinking it has anything to do with the adapter nor the jack. I read that there is a filter next to the jack that may lose contact over time that may cause this problem. The contacts (what I could see of them) looked OK there too.
This is a freebee, so I don't want to spend much time on it. Have any of you run across this problem with this laptop?
So far I am thinking that he would be better off buying a new laptop rather than spend money to replace a MB on a 5yr old Dell. But if it's something simple I am missing, I'd like to know.
Thanks for any responses.
Rick
Rick
