Larry Sabo
- Ottawa, Canada
<rant>
Man, this thing is a pain in the neck to work on. You can't remove the bezel by pulling up around the bezel inside edges and lifting off the bezel, because the lower lip of the bezel curls under the lid back. There is not enough clearance between the case and the lid to allow the bezel to be lifted out. You have to remove the laptop top cover (which was a chore in itself) and then the whole screen assembly in order to remove the bezel.
Even getting the hinge covers off was nearly impossible and I broke one of the little tabs that holds one of them in place. I think I'm supposed to remove the whole screen assembly to remove the hing covers! And the hard drive can't be removed without removing the top cover, either. I couldn't find a service manual or even a YouTube video on this new model variant, so it was a challenge.
The customer came to me very frustrated because Dell wouldn't cut her any slack on replacing the screen under warranty (or even consider a goodwill discount on the repair) because the laptop is just two weeks old. I don't have the heart to charge her for the extra time and frustration it has caused me.
</rant>
</rant>
