Eli
- Austin, TX
Finally hit an issue that I can't resolve... if anyone has any experience with this I'd love to hear about.
Got hired to install Win 10 on a T3600. Googled it before the job and looked like a simple issue of missing the Intel storage controller driver. But that solution didn't work--even if you find the missing "solved" link at the bottom of the page using the Wayback Machine.
It turns out the client is also a tech and he has been scratching his head about it for a few months (it's his own machine). He can use Windows just fine on the SATA ports but Windows sees no drives on the SAS ports (HDD0-4 on the mobo). He really wants to be able to use UEFI on HDD0.
As far as I can tell it's just a matter of getting the correct driver for the Intel C600 controller since there are no RAID cards in the system but damned if I didn't try every single possible driver I could--including those that come with Dell's latest enterprise WINPE. Even tried using the drivers with Win 7 and even then it didn't work.
The only difference between this issue and the one I linked is the machine can't even see HDD0-4 ports in the BIOS. Tried ctrl+i but no Intel configuration came up. Nothing in the BIOS itself seems to help. Also tried installing Windows on the SATA port and then installing drivers with good old Snappy Driver Origin which installed half a dozen SAS/SATA drivers and then shutting down and switching ports. No luck.
I've tried pretty much everything on the first page of half a dozen Google attempts but would appreciate it if anyone has any insights (hopefully we just missed something obvious). Or is this just not going to happen with UEFI on HDD0?
