PBComputer
- Carlisle, Cumbria, UK
I had this computer come in the other day with the following problem. When you try open Excel documents, the Excel splash screen says "Accessing Printer" and hangs. So I tried a system restore back a week or so, and the computer crashed (failed to boot). I was very short on time as they needing it working as soon as possible due to an audit so I re-installed the OS and set the system up again, Great all working. So on site and connect it backup, Install the printer and open a few documents all is fine. Before I leave we test again just to make sure, and the same problem is back. "Accessing Printer".
I was very short on time (Doctors and Dentist App) Else I would have stayed on site to sort it then. So I changed the default printer to the "One Note Printer" check again, and it works fine (they just need to change the printer each time... But it works.
If I open via "Excel / safe" it opens fine.
So I'm guessing the problem is with the printer driver?
I won't be able to access the system again until next week now.
The excel documents where created in Excel 97/2003/2007/2010/365 version of excel.
The computer runs Windows 8.1 Pro.
The Printer is a HP Officejet 4500
They have Office 365.
No add-on/plug-ins are running.
