Adept PC Repair
- Cardiff
Just to inform people, just in case they get a similar scenario.
I ordered a screen from LCDS4U (a reputable ebay seller). Upon installation in the Compaq CQ61 it was meant for the screen worked but had no backlight, previously the damaged screen lit up fine.
The laptop then would no longer power at all, upon closer inspection the ENE chip was scorching hot when the supply was plugged in.
I then proceeded to try the screen in a Toshiba Satellite C850 I have in for repair.
The screen previously was damaged but still lit up. Now with this screen connected, no backlight. I proceeded to try the original and again, no backlight.
I had to spend about 2 hours of my time fault finding and finally found a faulty backlight fuse on the toshiba, I replaced this and all is fine again.
However, I am now with a Compaq CQ61 which has a faulty ENE chipset.
I find this the most defective screen I have ever purchased, and will not be buying from LCDS4U again.
