tucsonpc
- Tucson, AZ
Awesome. I have 2 or 3 machines that have been 'searching for updates' for several hours now. Can't wait to get these buggers going!So much good info
I can't see the download link on this page. Any ideas?The closest thing to a service pack 2 for Windows 7 is this hotfix rollup.
https://support.microsoft.com/en-us/kb/2775511
If you are doing a fresh install you Install Windows 7, then install the SP1(if not already slipstreamed), then you install KB2775511, then install IE11, and then the WSUS Feb Patch KB3135445: https://support.microsoft.com/en-us/kb/3135445
Those steps will get you 90% of the way to a fully patched install.
thanks. <shakes head in disbelief>It's hiding over here: http://catalog.update.microsoft.com/v7/site/Search.aspx?q=KB2775511
You'll need to use Internet Exploder to get to it, though!
an the MSU and now I've had this little window on the screen for 2 hours called the Windows Update Standalone Installer, and the message is "Searching for updates on this computer"
If this doesn't work, there's also the Windows Update troubleshooter, which has worked sometimes for me. It can be executed from Tech Tool Store or UVK.In our shop we do a lot of re-imaging of customers' computers using Windows 7 Home Prem. and Professional. The past few months however, after clean installs of Windows 7, windows update fails to find updates no matter what course of action we take to fix it. Each failure usually comes with a different error code each time. This appears to be a common problem with 7 after extensively searching online and through these forums. There are a multitude of different fixes out there and some worked for us; most didn't.
So without further ado, I'm sharing with you all a legitimate *fix (it worked flawlessly on 3 out of 3 fresh Win 7 installs both x86 & x64) we finally found yesterday after hours of scratching our heads:
*Note this has only been tested on freshly CLEAN installs of Win 7 Home Premium & Professional with Service Pack 1! If you don't have Service Pack 1 installed, do so before attempting this.
1) Go here: https://support.microsoft.com/en-us/kb/3135445 download the correct bit version, save it somewhere on the PC (I would create a folder on desktop).
2) Save this in the same folder: http://windows.microsoft.com/en-us/windows7/what-is-the-system-update-readiness-tool
3) Disconnect from the internet. If using WiFi, disconnect and make sure to uncheck the "automatically connect to network" box.
4) Reboot. Make sure windows is offline, and install the first file KB3135445. It may take a few minutes. After installation, reboot again.
5) After boot, install the second file. The SUR Tool is a large file and may take much longer than the first one. The progress bar won't show anything for some reason. Patience, Padawan.
6) After SUR install, reboot again. Upon boot, reconnect to the internets and manually check for updates just like you normally would. Your mileage may vary, but ours took a bit to get going. In a few minutes, you should see a notification of some kind down in the toolbar regarding installation of updates, then the Windows Update icon. Success!
Follow these instructions to the T, make sure you have the right files and you should be golden! Any questions or unexpected problems, feel free to ask. This fix was a huuuge relief since we came across the update issues DAILY. Have a nice day :}
Here is another way to fully update a new win7 build:
http://www.freenode-windows.org/resources/vista-7/windows-update
That's about the same as I posted above it...except they added a 3rd KB download/install. We're doing the same with just the two I mentioned.Here is another way to fully update a new win7 build:
And actually don't need to disable the windows update service...I just did an Optiplex 380 rebuild (new SSD)...didnt' disable..just installed those first 2 KBs..rebooted...(took just about 1 minute total for both)...let it sniff for about 5-7 minutes..and a crapload of updates showed up and are now downloading/installed.
So just those first 2 KBs...done!
