Valhalla_tech
- NC
I've just got done spending 8 hours trying to setup a Zyxel USG40 to use IPSec VPN. I've read numerous documents and it's just not clicking for me, plus I'm exhausted from the other stuff I had to do on the network. Here is the scenario:
The client moved locations. Everything was setup, pretty much the way it is now, except for the ISP. They switched to FiOS from Xfinity. The setup was Modem/Router>Zyxel>Switch>Clients. Other than that, I don't know what the configuration was other than what I can see on the Zyxel web GUI. Whoever set it up didn't know what they were doing so there is a bunch of policies setup that were probably used in trial and error cases. I've never setup VPN from scratch, so I can't decipher the garbage from the working config.
Network components:
FiOS Quantum Modem/Router: DHCP off
Zyxel USG40
16 Port Unmanaged Switch
Windows Server 2016: DHCP, DNS, AD, DC
Five desktops
One laptop
Two printers
Goal: Laptop must be able to connect through VPN to the Zyxel, using Zyxel VPN client with IKEv1
When I connect the modem directly to the P1 WAN port on the Zyxel and the P2 LAN port to the switch, I cannot access the Fire Wall or ping it. If connect the Zyxel P1 and P2 ports to the switch, I can access it. However, I'm not sure if this is the right way to set it up. I thought about setting up port forwarding on the router to point IPSEC queries to the Zyxel. I haven't tested that theory yet. I have to go back on-site, tomorrow. Any help would be appreciated; I'm getting desperate. If I missed any pertinent info, I apologize, I'm burnt out. Also, I don't currently have screenshots, but I can provide some tomorrow.
tl;dr: I'm fudged...
Network components:
Zyxel USG40
Five desktops
One laptop
Two printers
