pcpete
We bought an AOYUE int968A a while back. We do a few dc jacks / month and some other lite soldering. We have been experimenting with the hot air portion for dc jack removal. I suspect our technique is horrible. Any suggestions on technique would be appreciated. I also have a few specific questions.
We have need setting the temp at about 435 C for both the hot air and the iron, is this to high?
We try to shield the are not wanting to heatup with a bit of foil, is this good, bad or do you have a better suggestion?
I noticed today on the board we were about to start removal of the jack(hence my post), there are surface mount "things" on the back side, do we need to worry they will also heat up and fall off?
