alexsmith2709
- UK
I had a guy come in saying his laptop wouldnt shutdown, it would just reboot when shutdown was clicked. Sure enough, thats what it was doing.
I disabled fast startup as that was enabled and that seemed to fix the issue, but then after another reboot i got an inaccessible_boot_device BSOD on boot.
I saw some updates were in a pending install state, so i used DISM /remove-package to get rid of those, but still get the same error.
It doesnt look like any drivers have recently been installed, but if anyone has a good way to tell the install date of drivers from recovery mode let me know. I used DISM /Get-Drivers but none had a recent date (in the past couple days)
SFC says files are OK as did DISM /RestoreHealth. HDD surface scan seems to be ok, AHCI is the only option for SATA in the BIOS. What else can i try? Is there a way to re-enable fast startup from the recovery environment as that is the only thing that has changed. No restore points are showing for a system restore.
