This has got several of us stumped on how to resolve this issue, which at first seems a fairly easy issue to overcome.
We uninstalled a corrupted installation of PC Tools Antivirus Free manually off a Vista 64 system (Gateway LX6810-01) due to a non-executable main module and uninstall module. We used Revo Uninstaller Pro to clean out the registry of all program data and files associated with this application. (This was done before effectively on another similar system). But this time, we also deleted the associated device drivers per instructions by the tech at PC Tools, hoping this might fix the problem with the app not executing when reinstalled.
computer > "system properties" > "advanced system properties" > "advanced" tab > "Environment Variables" > system variables /"New" > "variable name" = devmgr_show_nonpresent_devices > "Variable value"= 1
"hardware" tab > "device Manager" > "view > show hidden devices.
Deleted the 2 PCT entries (one main module, one for browser module)
On system restart.. no mouse, or keyboard function after Windows loads.
Now I feel stupid since I did not bing them or try to disable first before deleting, since I was (and still am) confident they were connected to PCTools only.
However, obviously something bad happened.
So keyboard and mouse work in WinRE and with bootable media, but they do not work in Safe Mode or anything inside of Windows. (Pointing to a problem with a device driver, I assume).
Obviously the only thing to do here is to do recovery options:
1. Went into the recovery module to run System restore. No restore points found (although we saw it create a restore point before we did anything, and no, this is not a dual boot system, just partitioned).
2. Ran the automated repair, didn't help.
3. Command prompt > chkdsk /r fixed some errors but didn't help.
4. sfc /scannow (no matter what options, it either cannot run, or says a scan is already scheculed. We also tried Offline bootdir, etc).
5. Rolled back the registry via command line to before we changed anything, using the backup stored by Revo. Didn't help.
Now we obtained a full Vista 64 Installation disk to boot from (original system was OEM):
Repair Installation
It asks what OS to repair, however none are listed. (Of course some may call this a sign of a critical error, but remember that Vista boots just fine! Just with no mouse or keyboard function).
When this is bypassed, it will basically not detect a hard drive and therefore cannot perform any installation or repair.
Going to the command prompt, this is verified by not being able to cd to any other drive but the boot DVD, (whereas in the recovery module, we could do so).
So no restore points, registry was rolled back, OS (HDD) seems not to be recognized in the recovery modules, sfc will not function, repair Vista installation and reinstall will not work because of the absent OS/HDD to choose from. (or lack of drivers?), although the OS is obviously intact and boots perfectly (so I'm not sure if trying anything with bootrec would be indicated?). Nothing can be done in Vista or Safe Mode because of no input method. I'm not sure if getting the OS recognized by WinRE would facilitate the repairs, or not, but to me it seems to be the main roadblock, whatever is causing that. We also made sure Legacy support was enabled in BIOS for USB and other devices, but the mouse/keyboard still do not work within Windows. Putting all of this together, I can only assume device drivers got deleted, with all routes to restore or repair them blocked by other issues.
Of course I could be totally wrong here. I consulted with a few other techs at repair shops who were actually more clueless than I am and suggested a full reinstall of the OS. Seriously? no other way to simply restore keyboard/mouse function than to wipe and reinstall an entire OS? I have to admit thinking of trying a Win7 Upgrade they obtained from Gateway, but maybe that is going in a bad direction until the underlying problems are fixed, not knowing what else might be affected negatively if the initial problems were not repaired by the upgrade.
Needless to say, I am at a loss here. The answer might be something simple I haven't thought of, but this seemingly simple problem (with a fully bootable OS and no other errors), has got about 4 of us stumped.
Any ideas on this?
Repair Installation
Any ideas on this?
