georgenoise
- Gueydan, La
I'm wondering if anyone out there happens to consider themselves an expert when it comes to KMS troubleshooting and maybe has a solution I haven't looked at. I have a client that uses KMS with their VDI setup(Hyper-V w/ vWorkspace management, non-presistent desktops), I'm not the one that originally setup the KMS so I don't know if it was done correctly originally or what was done. Before the Christmas break everything worked fine, now that they have returned all the vdi workstations are reporting that W7 isn't genuine and needs to be activated. Office also uses KMS and is having no issues, just the OS.
I've tried just about everything I know: DNS records are correct, nslookup verifies that too, I tried to rearm but it was at 0 so i had to reset the rearm, it rearmed but changed nothing, /ato to force activation will give an error that the count is insufficient from the KMS host but the count isn't increasing as machines hit it(assuming they hit it), I've tried a few other things to no avail that I can't recall.
The only thing I can guess is the issue is that the when a new vm spins up from the base image it isn't creating a new CMID, it just keeps the original from the base image. I tried to use the "sysprep /generalize /oobe" command to remedy this but it doesn't seem to change anything. Problem with that theory is that it has been working, no problems, for almost a year now.
My other theory was that the KMS key is possibly compromised and MS has something to do with it.
So anyway, if anyone out there happens to have a solution or tip please send it my way. I would grealy appreciate it.
