Metanis
- Medford, WI, USA
Like many computer techs I've accumulated a lot of hardware over the years. A few days ago I gathered up some bits and pieces and decided to build a new Linux Mint box. For example I have a nice Gigabyte AMD motherboard with a Phenom II X6 1100T 3.3GHz CPU and 8GB of RAM. Even though 8 years old that's still a very capable CPU.
Since I had 3 identical Sata-II 160GB drives I'd thought I'd build a fast little Raid-0 array since reliability wasn't really a concern.
2 full days later and I still can't get Linux Mint 19 to install or boot on that raid array. First I tried the fake hardware raid built into the Gigabyte motherboard. But there doesn't appear to be any way to 'insert' a raid driver during Linux setup. The Linux installer actually recognizes the Raid array but is determined to ignore it as a valid installation destination. It want's to install directly onto the first actual hardware drive /dev/sda.
So then I decided to use the Linux software raid utility MDADM and forget the motherboard. Well sure you can boot the live setup DVD and create the raid and you can even get Mint to install to it but you can't make it bootable once the installation is over. It doesn't appear to be able to figure out how to install the various grub and bootloader components without a serious session of command-line hand holding with root privileges.
I'm sure there is a way to do it but after reading dozens of message board threads nothing actually works. It seems you have to become a Linux boot configuration specialist in order to figure out the right combination of commands.
Now with Windows 7 I simply copied the Raid driver to an old flash drive and inserted it during the installation and chose to install the driver before choosing the Raid array as a valid installation target. It booted normally and without me issuing a single command.
Oh yes, there's plenty of threads out there to assist you. But most of them pertain to Raid 1 and the procedure doesn't work on Raid 0. Or they recommend you install Linux to a single disk first and then clone the installation to your raid array. Or the instructions pertain to GPT and EFI bios partitions and not MBR. Or they assume you understand the purpose and syntax of the 45-step procedure you need to follow and can correctly substitute the correct variables based on your specific parameters. (I'm not joking, it was a 45-step process on the particular site/thread I was reading!)
I can distinctly understand Microsoft's willingness to remove their corporate focus from their OS products. They can coast for another 20 years before Linux will truly challenge them for market share.
Anyway, this was just a rant. I'll throw a Server 2016 eval key on there instead. Or maybe a preview of 2019.
