Mike McCall
- Silverton, Oregon
In a more complete quote I said:
"Clearly the drive needs to be replaced, but I'm not sure it's the root cause. I won't suggest the client replace the drive unless I'm sure it's the problem. I'm conflicted because performing First Aid via Disk Utility has no effect, won't boot into safe mode but will into recovery mode. If It will properly display the screen in recovery mode it seems to rule out a GPU problem."
But you cut it down to the first 7 words (Clearly the drive needs to be replaced), when you quoted me and ignored everything else said both in the above paragraph and throughout this thread.
So, you find fault with my concluding that an 8-year old HDD should be replaced, tell me I'm not wrong about it, and then say we're actually agreed on this? Perfect. Got it.
Ok, clearly I'm acting prematurely when I say that an 8-year old HDD should be replaced, but I'm now also wrong because I prefer err on the side of caution by removing the laptop battery? You don't like the way I look or something?
This:
And you're not wrong, but you need to figure out the cause of the fault before doing anything. I think we're actually agreed on this!
What makes you think you need to remove the battery before replacing the RAM?
https://support.apple.com/en-us/HT201165
