glennd
- South West Victoria Australia
Customer brought me a Macintosh A1398 (2012?). Over about half an hour of discussion a picture began to emerge which goes something like this: In 2018 the laptop developed issues, she took it to the shop from whence it came, they replaced the HDD with an SSD. The entire user folder was backed up to a WD external usb drive (over 200GB). I don't know if they did some kind of migration or just a clean install on the new SSD. Because the new SSD (250GB) was apparently much smaller than the original HDD they were unable to restore her vast photo library (she's a photographer) and so it stayed on the WD. Now when we run the Photos application, it throws an error if the WD is not plugged in, because the library is not available. If the WD is plugged in, it runs but really really *really* slowly.
She's put up with it since then but finally took it back to the shop. They said it's all working fine and charged her $70. It's clearly not working fine. You could argue it technically is working properly but the way they set it up to run Photos on the external drive is plain stupid.
So, my solution is to replace the SSD with 1TB or bigger so the Photo library can go back on to the laptop. My problem is I've never done this on a Macintosh. My question is, can I use the same process as I would for a Windows machine? Can I clone it to a new drive from a Windows/Linux box? I don't know what else I need to know. I need to decide if I even want to attempt this or pass it to a Mac tech.
