timeshifter
- USA
About two years ago I installed 4 UniFi APs in a very large, old, 3 story house. It's been trouble free.
Two days ago I installed a new wireless printer and I installed a UPS. The printer is probably not even related. The UPS I installed to power their cable company modem / router combo and all the power injectors for the 4 APs. This required unplugging everything and plugging it all back. Shouldn't be a big deal. I did't go around and check or inspect each AP. But it was working after unplugging and plugging things in behind the UPS. I used my laptop on their WiFi for about 5 minutes afterward.
I noticed during all this that their modem / router combo (supplied by the cable company) had it's 2.4 and 5 GHz lights on. I was going to go in and disable that default setting as I was expecting to see the standard SSID and password as supplied by the factory. I was surprised to find that it had been programmed to match the UniFi system. I NEVER SET THAT UP. I always disable cable company WiFi when I do such an install. But in that moment I didn't recall doing that and thought the guy I worked with on the wiring did that (he often does), so I didn't want to undo things that had been working.
About an hour after I left I got a call. They couldn't get on their WiFi. All of their iPhones were saying "Incorrect Password". Their MacBook laptop couldn't connect either.
I walked them through a reset. Had them unplug the modem power and all 4 injectors. Then I had them power on the modem and wait until it was all the way up, and they connected to it's WiFi. Then they powered up the rest of the APs. Then they could connect and within a few minutes everything was working, including a few WiFi security cameras.
A day later I get a text that they can't get on their network. That's where I'm at now. I looked at my invoice and I had noted that I had disabled the cable company's WiFi. Also, I'm pretty sure the modem came after my install as the cable company had a big city-wide upgrade and everyone got new modems.
For reasons I can't articulate, I ALWAYS like to disable the WiFi from other manufacturers and use the same SSID on like hardware from one company - like a typical UniFi installation.
QUESTION: Is mixing and matching like that generally a bad idea? Or do you think it's no big deal?
